ArcGIS Online Custom Attribute Display Line Spacing
2823
07-27-2015 06:47 AM
ToddHenry1
I want to remove the extra line break between two lines in a custom attribute display.  I had it happen once when adding fields, but I'm not sure exactly how I did it.
Now it looks like this:
Address
City, State Zip
and I want
Address
City, State Zip
Thanks.
JamesFrank
New Contributor III
Hi Todd,
What I have found is that has occured for me depending on how I get the text into the box.  Copy and paste will give the extra spacing (I think from Word is where I saw it the most) or when I publish from ArcGIS Pro.  For those instances, I have added to my publishing workflow to open the Custom Attribute Display dialog and for each line Delete the return and then re-enter the return.  It is not a great solution but it has worked for me.
Good luck!
Jim
