Updating this thread-
We've upgraded to Enterprise 11.2 and we are now able to see the ability to edit related records.
For those who stumble across this, here is more documentation for this functionality :
https://doc.arcgis.com/en/arcgis-online/create-maps/create-form-mv.htm
Something that I didn't find clear though, that I hope this post saves you some time (maybe I missed it)-
When you're creating the form for the related table you need to:
- Ensure both Points and related tables are in the map viewer (this is documented)
- Add the related table to the form for the points feature layer (this sets up the form relationship) see diagram below:
1. Add the relationship to your parent layer form:
3. Go to the table in the map viewer and add the fields to the related table & configure conditions from here
Once you save the map, the related table fields will be visible in other applications when editing the parent point layer's information:
(add new record or edit existing)
Hope this helps someone who comes across this!
Best,
Amanda Huber
