arcgis online unable to import this shapefile
709
07-30-2018 02:23 AM
MarcoOrlandi1
I have some shp created in QGis that I'm trying to import in a pubblic account of AGOL (so "import from file" --> Zip shp)
but I Keep getting this error (with no specification number).
I tried the same way before with other shp and everything was nice and smooth.....
I can visualize them correctly both with QGis and ArcMap.
Please Help!!!!
p.s.: in Qgis I just have a WGS84 Coordinate system, no projection... maybe this is the problem? How to fix it?
Thanks!
KellyGerrow
Esri Frequent Contributor
Can you share the shapefile?
DanPatterson_Retired
and even try to save it out to another copy of the shapefile, maybe Arc* will tolerate it, but make a better copy on the way out
