Bug when publishing tiled map service with labels
427
11-14-2012 08:57 AM
DavidButz
New Contributor III
I have a simple polygon layer that I have in ArcMap. I labeled it using a simple VBScript expression to make a label such as "ID: [myIDField] so it will show 'ID: 234' for example.
After I publish this to ArcGIS Online as a tiled map service, the labels appear but only show the part of the label in quotes and NOT the part of the label pulled from the attribute table. So I only see "ID:" after publishing.
Why is this?
MikeMinami
Esri Notable Contributor
I am not seeing this behavior. You do see the labels appear in ArcMap, right? Did you use a special text symbol or set scale range?
Mike
DavidButz
New Contributor III
Hi Mike,
Yes, the labels appear correct in ArcMap. My boss was on the phone with ESRI support yesterday while I was researching this issue in the forums. He was given an incident/bug number of 1096691
There was no special text symbol and I am pretty sure there was no scale range settings either.
David
