Cannot edit feature class that participates in geometric network
3201
08-10-2011 02:28 PM
MarkChambers1
I am unable to edit a feature service that has a feature class that participates in a geometric network.  When I remove the geometric network I can edit without issues?  Is this a restriction for editing on ArcGIS Online.
Mark C>
GaryMacDougall
Is the data in the geodatabase versioned? - it must be versioned in order for a  geometric network to be edited
thanks
Gary
RichardTruong
My GDB is versioned, however, I was able to edit the table data, but not able to edit geometry (ex. move existing point feature).  Again, is there a way to temporary disable geometric network when perform edit feature?  Thank you, Richard
RichardTruong
Hi Gary,
Sorry for the delay.  Spoke with ESRI support and come to find out if I decided to use feature with Geometric Network, then I must create my own baseman using my own projection and etc.  Then after data being collected, then reprojected back to AGOL baseman projection.    Thank you.  Richard
