Changing Polygon Outline thickness by scale
788
06-16-2021 01:37 PM
Labels (3)
CalebWilliams2
Good afternoon,
I need my data to stay in one layer, and exist as polygons, but I also need to be able to see them from pretty far away. So I was wondering if it was possible to have polygon border thickness change with scale. Getting thicker the further you zoom out.
DavidPike
MVP Frequent Contributor
I had a quick test of using an expression based on map scale in the new map viewer (previous beta).  But I wasn't able to change the outline thickness.  You might have more luck as I may be missing something simple.
This was the quick expression ('Styles on the rightHandSide) -> Choose attributes - New Expression) Then I just chose Types(Unique Symbols) and set the properties for the the current and 'other'.
if ($view.scale > 100000 ) {
  return 1
else {
  return 10
