Combine Polylines
8160
08-07-2015 05:45 AM
RusselQuan
New Contributor III
How would you combine a Feature Class of Polylines into a single Single Polyline Objects to reduce the number of Objects from many to one?  The goal is to reduce the number credits for storage, and potentially increase the speed for rendering.
I've tried Dissolve and Merge but the number of Object remains the same as the original.
Thanks.
Tags (1)
ChrisSmith7
If you are using ArcMap 10.x and have an Advanced/ArcInfo license, you can try running a multipart to single part tool, then using the unsplit line tool:
http://resources.arcgis.com/en/help/main/10.1/index.html#//001700000040000000
Merges lines that have coincident endpoints and, optionally, common attribute values.
You may need to run a topology check, too, to make sure your polylines are coincident.
ChrisSmith7
RusselQuan
New Contributor III
Thanks Chris.  It worked!
