I'm creating a custom map marker for a web map i'm putting together. I found this pretty helpful ESRI tutorial:
https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/using-images-as-custom-point-symbols...
I used Illustrator to create the map marker and per the instructions in the url above, positioned the tip of the map marker on the center of the art-board so it's eventually placement in my web map is correct (as opposed to being pushed down). The problem, however, is when I select an icon in the web map, the neon-blue outline that appears when clicking on a feature shows the ENTIRE artboard outline (see attached). Is there anyway to minimize this? The area that it selects is just way too large relative to the icon. Any help is appreciated. Thanks
-fd
