I know I am not the first person to raise this question...
I have a numeric field in ArcGIS Pro that contains a mixture of whole numbers and decimals (up to four decimal places), i.e. 30, 15.7, 0.59 etc. I need the values to be numeric as I need to add them to a dashboard and perform calculations.
When I publish to AGOL I run into the same issue that others have identified, with the field I now need to set a number of decimal places..
If I set it to four decimal places I get 30.0000, 15.700, 0.5900
If I set it to Zero Decimal places I get 30, 16, 1
The workaround I have found is to create duplicate field in Pro as text, and copy the values in there. I then use this as the display field in AGOL, but its a bit of a pain..
Does anyone know if there is a better solution for this? Or is there way of adding AGOL honouring values as imported from Pro as an idea?
Paul
