If you have a decent internet connection in the field just tap "submit" after each feature with a photo attachment is collected. Then to get the photos attached to the file GDB, add the AGOL Feature service to an MXD in desktop, sign is as a User or Publisher (cannot be as an Administrator or your next step will result in an empty GDB), then right click, Edit, Create a local copy for editing and you will find that the photos are attached. I then rename and archive as a backup. This solution was from ESRI support after changing symbols in my web map hosed my data schema in Collector and I had to manually reattach photos by saving them to the ipad, emailing them to myself and attaching them to the features in an AGOL edit session...
