Eratic Toolbar Behavior on Basic Template
3996
6
02-18-2015 07:47 AM
LisaStapleton
New Contributor III
We have been making adjustments to our ArcGIS services during the last couple of weeks. We use the AGO basic templates for all of our applications. Sometimes the tools fall off of the toolbar, other times the tools appear but don't work. This morning for example, all of the tools are displayed but when you click them, nothing happens, the menus don't appear on the right side as they usually do. Strangely, you can see the scroll bar moving down as if the menus are being displayed. Has anyone else been seeing this behavior? Surely we don't have to open and resave our applications every time we republish our services, do we? By the way, the data displays fine. That's the odd thing - it's just the tools that aren't behaving.
KellyHutchins
Esri Frequent Contributor
Is the link to your app public? If so can you provide the url. Are you able to reproduce this issue in all browsers?
LisaStapleton
New Contributor III
No, our apps are not public.We only use Chrome.
See screen shot below. Notice that some of the tools aren't appearing on the toolbar. This is a typical problem. Today's issue started with all the tools displayed but not working. We are on the phone with esri tech support now.
KellyHutchins
Strange - haven't seen that behavior before. One thing to check might be to open the console in Chrome Developer Tools then re-run the app to see if there are any errors displayed. Esri support should be able to help you with that step if you haven't done it before.
LisaStapleton
New Contributor III
As they are working through the issue, it's back to the way it was first thing this morning. All of the tools but when you click on them, they don't do anything. Look at this series of screen shows and note that as I select the tools, the scroll bar moves down as if it thinks it is displaying.
ChrisSergent
Regular Contributor III
I typed the root URL of http://tacomawater.maps.arcgis.com/apps/Viewer/index.html  and your print tool is throwing an error:
POST http://tacomawater.maps.arcgis.com/sharing/proxy?http://twgreenriver1/twpub…ervices/Utilities/Printi... 400 (Bad Request)
init.js:192 q {message: "Unable to load http://tacomawater.maps.arcgis.com/…ver/Export%20Web%20Map%20Task/execute status: 400", response: Object, status: 400, responseText: "", xhr: XMLHttpRequest…}
Print.js:9 q {message: "Unable to load http://tacomawater.maps.arcgis.com/…ver/Export%20Web%20Map%20Task/execute status: 400", response: Object, status: 400, responseText: "", xhr: XMLHttpRequest…}
init.js:162 GET http://twgreenriver1/twpub/rest/info?f=json net::ERR_NAME_NOT_RESOLVED
LisaStapleton
New Contributor III
Thanks! I'll pass that along to my tech guy. I'm just the manager, wringing my hands while all of my users call and email me the problems!
