I am working with Survey123, trying to work out a totally different bug (error code 1003), and to do this I am attempting trial and error methods, which involves changing one thing and republishing the survey. I notice that as the middle of the day comes around I start receiving error codes 502 and 503. Sometimes one then sometimes the other. I am assuming it is trouble with servers or something upstream having to do with too much traffic on the server in the middle of the day, since I can run things fine early in the morning and late in the evening. I would like to be able to work on issues during normal working hours (crazy right?) is there something you all at ESRI can do to fix this? Thanks and cheers!
