I have an error storing credentials on secured service in AGOL that results in a 502 Bad Gateway
After adding the item, and storing my credentials, I attempt to add the service to my map and I get an error 502 bad gateway. If I attempt to browse to the new rest endpoint at utility.arcgis.com I get an ArcGIS Portal Directory Error.
******************** ArcGIS Portal Directory | Home Error You do not have permissions to access this resource or perform this operation.
Error: 403 ********************
I'm using server 10.2.2 sync sync-enabled feature service. (GIS Tier Authentication)
I've tested this with map services too and also on a computer that is completely off of my company domain.
Did you find any resolution to the 502 bad gateway issue? I currently have the same problem on a production server install although my development and test environments are working fine with the same configuration. My secured services can be added directly to a web map with no issues, but can't be used to create a service item with stored credentials.
Our issue ended up being that IIS had been inadvertently set to accept client certificates in the SSL settings. Once we set it back to ignore client certificates, everything worked as expected.
You solved the original issue with that answer you just posted. I've been on at least two support calls with Esri to tier 2 and they were stumped. We thought we were chasing a whitelist ip address issue, but I guess not. Thank you so much for sharing.
Glad that helped! I burned a week on it last week...was almost at the point of rebuilding the whole config until I decided to review the IIS SSL settings since someone else had done the initial setup.
Portal error : when I am trying to access secured rest service which I added as an item and shared with a group. and when I try to access this url I get this error : You do not have permissions to access this resource or perform this operation
catch(e){
if (newSub.getAttribute("slang").toLowerCase() != code_l.toLowerCase()) {
if (trLabelsHtml != "") {
var labelSname = "";
if(labelEle[i].querySelector("ul li:nth-child(1)").getAttribute("aria-hidden")){
labelSname = labelEle[i].querySelector("ul li:nth-child(1)").outerHTML;
labelEle[i].innerHTML = "";
labelEle[i].innerHTML = labelSname + trLabelsHtml;
catch(e){
/* V 2.0:3 = Store not translated reply id */
if(lingoRSXML.snapshotLength == 0){
if($scope.falseReplyID == "") {
$scope.falseReplyID = value;
/* Get translated Body of Replies/Comments */
var lingoRBXML = doc.evaluate(lingoRBExp, doc, null, XPathResult.UNORDERED_NODE_SNAPSHOT_TYPE, null);
for(var i=0;i 0) {
var attachDiv = rootElement.querySelector('div.lia-quilt-row-main').querySelector('div.custom-attachments');
if (attachDiv) {
attachDiv = attachDiv.outerHTML;
else if(rootElement.querySelector('div.lia-quilt-row-main').querySelectorAll('#attachments').length > 0){
if ("ForumTopicPage" == "BlogArticlePage") {
attachDiv = rootElement.querySelector('div.lia-quilt-row-main .lia-message-body-content').querySelector('#attachments');
if (attachDiv) {
else{
attachDiv = "";
}else{
attachDiv = rootElement.querySelector('div.lia-quilt-row-main').querySelector('#attachments').outerHTML;
else {
attachDiv = "";
/* Feedback Div */
var feedbackDiv = "";
var feedbackDivs = rootElement.querySelector('div.lia-quilt-row-main').querySelectorAll('div.lia-panel-feedback-banner-safe');
if (feedbackDivs.length > 0) {
for (var k = 0; k < feedbackDivs.length; k++) {
feedbackDiv = feedbackDiv + feedbackDivs[k].outerHTML;
else {
var attachDiv = rootElement.querySelector('div.lia-message-body-content').querySelector('div.Attachments.preview-attachments');
if (attachDiv) {
} else {
attachDiv = "";
/* Everyone tags links */
if (document.querySelectorAll("div.TagList").length > 0){
var everyoneTagslink = document.querySelector('div.lia-quilt-row-main').querySelector(".MessageTagsTaplet .TagList");
if ((everyoneTagslink != null)||(everyoneTagslink != undefined)){
everyoneTagslink = everyoneTagslink.outerHTML;
else{
everyoneTagslink = "";
/* Feedback Div */
var feedbackDivs = rootElement.querySelector('div.lia-message-body-content').querySelectorAll('div.lia-panel-feedback-banner-safe');
for (var m = 0; m < feedbackDivs.length; m++) {
feedbackDiv = feedbackDiv + feedbackDivs[m].outerHTML;
} catch (e) {
if (body_L == "") {
/* V 2.0:7 Replacing translated video data with source video data */
var newBodyVideoData = newBody.querySelectorAll('div[class*="video-embed"]');
angular.forEach($scope.videoData[value], function (sourceVideoElement, index) {
if (index <= (newBodyVideoData.length - 1)) {
newBodyVideoData[index].outerHTML = sourceVideoElement.outerHTML
/* V 2.0:7 = Replacing translated image data with source data */
var newBodyImageData = newBody.querySelectorAll('[class*="lia-image"]');
angular.forEach($scope.imageData[value], function (sourceImgElement, index) {
if (index <= (newBodyImageData.length - 1)) {
newBodyImageData[index].outerHTML = sourceImgElement.outerHTML;
/* V 2.0:7 = Replacing translated pre tag data with source data */
var newBodyPreTagData = newBody.querySelectorAll('pre');
angular.forEach($scope.preTagData[value], function (sourcePreTagElement, index) {
if (index <= (newBodyPreTagData.length - 1)) {
newBodyPreTagData[index].outerHTML = sourcePreTagElement.outerHTML;
var copyBodySubject = false;
if (body_L == "") {
copyBodySubject = true;
body_L = newBody.innerHTML;
/* This code is written as part of video fix by iTalent */
/* try{
var iframeHTMLText = body_L;
var searchIframeText = "<IFRAME";
var foundiFrameTag;
if (iframeHTMLText.indexOf(searchIframeText) > -1) {
foundiFrameTag = decodeHTMLEntities(iframeHTMLText);
foundiFrameTag = foundiFrameTag.split('src="')[1];
body_L = foundiFrameTag;
catch(e){
/* This code is placed to remove the extra meta tag adding in the UI*/
try{
body_L = body_L.replace('<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />','');
catch(e){
/** We should not replace the source content if user profile language and selected target language matches with source language **/
if(showTrContent) {
var compiled = false;
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = null
if("ForumTopicPage"=="IdeaPage"){
// var customAttachDiv = '';
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = body_L + feedbackDiv ;
$compile(rootElement.querySelectorAll('div.lia-message-body-content')[0])($scope);
compiled = true;
/* Attach atttach div */
// document.querySelector("div.translation-attachments-"+value).innerHTML = attachDiv;
rootElement.querySelectorAll('div.lia-message-body-content')[0].insertAdjacentHTML('afterend',attachDiv);
if(rootElement.querySelectorAll('div.lia-quilt-idea-message .lia-message-body .lia-attachments-message').length > 1){
rootElement.querySelectorAll('div.lia-quilt-idea-message .lia-message-body .lia-attachments-message')[1].remove();
} else {
if("ForumTopicPage"=="TkbArticlePage"){
}else{
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = body_L + feedbackDiv + attachDiv;
compiled = true;
/* Destroy and recreate OOyala player videos to restore the videos in target languages which is written by iTalent as part of iTrack LILICON-79 */ /* Destroy and recreate OOyala player videos */
try{
// $scope.videoData[value][0].querySelector("div").getAttribute("id");
for(var vidIndex=0; vidIndex<$scope.videoData[value].length; vidIndex++){
if( $scope.videoData[value][vidIndex].querySelector("div") != null){
var containerId = LITHIUM.OOYALA.players[$scope.videoData[value][vidIndex].querySelector("div").getAttribute("id")].containerId;
videoId = LITHIUM.OOYALA.players[$scope.videoData[value][vidIndex].querySelector("div").getAttribute("id")].videoId;
/** Get the Video object */
vid = OO.Player.create(containerId,videoId);
/** Destroy the video **/
vid.destroy();
/** recreate in the same position */
var vid = OO.Player.create(containerId,videoId);
catch(e){
try{
for(var vidIndex=0; vidIndex<($scope.videoData[value].length); vidIndex++){
if($scope.videoData[value][vidIndex].querySelector('video-js') != null){
var data_id = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-video-id');
var data_account = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-account');
var data_palyer = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-player');
var div = document.createElement('div');
div.id = "brightcove";
div.class = "brightcove-player";
div.innerHTML =
'(view in my videos)'
var data = div.getElementsByClassName("video-js");
var script = document.createElement('script');
script.src = "https://players.brightcove.net/" + data_account + "/" + data_palyer + "_default/index.min.js";
for(var i=0;i< data.length;i++){
videodata.push(data[i]);
for(var i=0;i< videodata.length;i++){
document.getElementsByClassName('lia-vid-container')[i].innerHTML = videodata[i].outerHTML;
document.body.appendChild(script);
catch(e){
if(!compiled){
/* Re compile html */
if (code_l.toLowerCase() != newBody.getAttribute("slang").toLowerCase()) {
/* Adding Translation flag */
var tr_obj = $filter('filter')($scope.sourceLangList, function (obj_l) {
return obj_l.code.toLowerCase() === newBody.getAttribute("slang").toLowerCase()
if (tr_obj.length > 0) {
tr_text = "Esri may utilize third parties to translate your data and/or imagery to facilitate communication across different languages.".replace(/lilicon-trans-text/g, tr_obj[0].title);
try {
if ($scope.wootMessages[$rootScope.profLang] != undefined) {
tr_text = $scope.wootMessages[$rootScope.profLang].replace(/lilicon-trans-text/g, tr_obj[0].title);
} catch (e) {
} else {
//tr_text = "This message was translated for your convenience!";
tr_text = "Esri may utilize third parties to translate your data and/or imagery to facilitate communication across different languages.";
try {
if (!document.getElementById("tr-msz-" + value)) {
var tr_para = document.createElement("P");
tr_para.setAttribute("id", "tr-msz-" + value);
tr_para.setAttribute("class", "tr-msz");
tr_para.style.textAlign = 'justify';
var tr_fTag = document.createElement("IMG");
tr_fTag.setAttribute("class", "tFlag");
tr_fTag.setAttribute("src", "/html/assets/langTrFlag.PNG");
tr_fTag.style.marginRight = "5px";
tr_fTag.style.height = "14px";
tr_para.appendChild(tr_fTag);
var tr_textNode = document.createTextNode(tr_text);
tr_para.appendChild(tr_textNode);
/* Woot message only for multi source */
if(rootElement.querySelector(".lia-quilt-forum-message")){
rootElement.querySelector(".lia-quilt-forum-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-message-view-blog-topic-message")) {
rootElement.querySelector(".lia-message-view-blog-topic-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-blog-reply-message")){
rootElement.querySelector(".lia-quilt-blog-reply-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-tkb-message")){
rootElement.querySelector(".lia-quilt-tkb-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-tkb-reply-message")){
rootElement.querySelector(".lia-quilt-tkb-reply-message").insertBefore(tr_para,rootElement.querySelector(".lia-quilt-row.lia-quilt-row-footer"));
} else if(rootElement.querySelector(".lia-quilt-idea-message")){
rootElement.querySelector(".lia-quilt-idea-message").appendChild(tr_para);
} else if(rootElement.querySelector('.lia-quilt-occasion-message')){
rootElement.querySelector('.lia-quilt-occasion-message').appendChild(tr_para);
else {
if (rootElement.querySelectorAll('div.lia-quilt-row-footer').length > 0) {
rootElement.querySelectorAll('div.lia-quilt-row-footer')[0].appendChild(tr_para);
} else {
rootElement.querySelectorAll('div.lia-quilt-column-message-footer')[0].appendChild(tr_para);
} catch (e) {
} else {
/* Do not display button for same language */
// syncList.remove(value);
var index = $scope.syncList.indexOf(value);
if (index > -1) {
$scope.syncList.splice(index, 1);
/* V 1.1:2 = Reply Sync button for multi source translation */
} catch(e){
console.log(e);
if((rContent != undefined) && (rContent != "")) {
drawCanvas(decodeURIComponent(rContent));
/** Update variable with selected language code **/
$scope.previousSelCode = code_l;
* @function manageTranslation
* @description Managess the translation of given language for the thread
* @param {string} langCode - Language Code
* @param {string} tid - Thread ID
$scope.manageTranslation = function (langCode, tid) {
//debugger;
$scope.showTrText = false;
/* V 2.0:5 = actualStatus variable introduced to indicate detailed connector status on UI. This variable holds the actual translation percentage */
$scope.transPercent = "";
$scope.actualStatus = "";
if (tid != "") {
var bulkTranslation = lithiumPlugin.bulkTranslation(langCode, tid);
bulkTranslation.then(function (trContent) {
if(trContent.body != "") {
$scope.showPreview(trContent.body, $scope.mszList, langCode);
if(langCode != "en-US") {
$scope.showTrText = true;
if((trContent.status != "NA") && trContent.status != null) {
// $scope.transPercent = String(trContent.status);
$scope.actualStatus = String(trContent.status);
} else {
// $rootScope.errorMsg = "Translation is in progress. Please check again a few minutes."
$rootScope.errorMsg = "Translation is in progress. Please retry in a few minutes."
$scope.workbench = trContent.wb;
/* V 2.0:4 = Trigger uncalled or delayed callbacks (documnet uploaded/translation completed from lithium).*/
if(trContent.callback == 'true') {
var trCompletCallback = lithiumPlugin.trCompletCallback(langCode, trContent.docID);
trCompletCallback.then(function (callback){
// $rootScope.errorMsg = "Downloading Translated content in " + langCode + " now. Please check again in a few minutes."
$rootScope.errorMsg = "Uploading content to translate. Please check again in a few minutes."
} else if (trContent.callback == 'upload') {
var trCompletUpload = lithiumPlugin.trCompletUpload(langCode, trContent.docID);
trCompletUpload.then(function (callback) {
//$rootScope.errorMsg = "Uploading content to translate. Please check again in a few minutes."
} else if ("many" == "one") {
$scope.updateOOS();
} else if("SmartConx" == "SmartConx"){
if ("many" == "many"){
$scope.updateOOS();
}else if ((trContent.status != null) && trContent.status.includes("100")) {
/* If everything fine then only check Out of Sync status */
$scope.updateOOS();
} else {
/* If translation perccent is less than 100 then show the percentage on UI */
$scope.transPercent = $scope.actualStatus;
* @function selectThisLang
* @description Called on select dropdown.
* @param {string} lang - Language code
$scope.selectThisLang = function (lang, anonymousFlag) {
/* 1.4:3 Update Analytics on language selection */
try {
lingoThreadLangSelected(lang, '751256');
} catch (e) {
/** Display Translated content **/
var getTranslation = lithiumPlugin.getTranslation(lang, "751256");
getTranslation.then(function (trContent) {
if (trContent.body != "") {
$scope.showPreview(trContent.body, $scope.mszList, lang);
} else {
//$rootScope.errorMsg = "Translation is in progress. Please check again in a few minutes."
var decodeEntities = (function() {
// this prevents any overhead from creating the object each time
var element = document.createElement('div');
function decodeHTMLEntities (str) {
if(str && typeof str === 'string') {
// strip script/html tags
str = str.replace(/
