Error with ArcHydro / HEC-GeoHMS Terrain Preprocessing Build Walls / DEM Reconditioning tools
1425
01-28-2020 10:20 AM
TungNg
Hi everyone,
I had these errors while running Build Walls and DEM Reconditioning tools in either HEC-GeoHMS or ArcHydro
System info:
  • ArcGIS version 10.6.1
  • HEC-GeoHMS 10.6: downloaded from here
  • Filled DEM (Fil) in C:/GIS/Layers
  • Inner/Outer Wall layer (wall_test_buf.shp) in C:/GIS/Layers: is a buffer (30 feets) created from a line feature
Errors:
Executing: BuildWalls Fil 500 0 0 C:\GIS\Layers\WalledDEM # wall_test_buf #
Start Time: Tue Jan 28 12:58:16 2020
Building internal walls
Executing: CreateFeatureclass C:\Users\user007\AppData\Local\Temp\arc2C59\AH20200128095816\AHTemp.gdb tmpAD66 POLYLINE # DISABLED DISABLED "PROJCS['NAD_1983_UTM_Zone_10N',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',1640416.666666667],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-123.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Foot_US',0.3048006096012192]];-16800800 -32802000 137296494.950628;-100000 10000;-100000 10000;3.28083333333333E-03;0.001;0.001;IsHighPrecision" # 0 0 0
Start Time: Tue Jan 28 12:58:17 2020
Succeeded at Tue Jan 28 12:58:18 2020 (Elapsed Time: 0.48 seconds)
Executing: PolylineToRaster GPL0 OBJECTID C:\Users\user007\AppData\Local\Temp\arc2C59\AH20200128095816\wtemp MAXIMUM_LENGTH NONE 10
Start Time: Tue Jan 28 12:58:18 2020
Succeeded at Tue Jan 28 12:58:18 2020 (Elapsed Time: 0.50 seconds)
System.Runtime.InteropServices.COMException (0x80041098): ERROR 010429: Error in GRID IO: CellLyrCreateInternal: Unable to create cell layer directory c:\windows\system32\ras810 .
ERROR 010302: Unable to create the output raster: C:\WINDOWS\SYSTEM32\RAS810
ERROR 010067: Error in executing grid expression.
at ESRI.ArcGIS.SpatialAnalyst.RasterMathOpsClass.IsNull(IGeoDataset geoDataset)
at ESRI.APWR.ApHydro.ArcHydroOp.BuildWalls(ApLayers apLayers, Double innerWallHeight, Double wallBuffer, Double breachLineBuffer, ITrackCancel& trackcancel, IGPMessages& messages, String& exMessage)
Failed to execute (BuildWalls).
Failed at Tue Jan 28 12:58:19 2020 (Elapsed Time: 2.11 seconds)
Executing: DEMReconditioning Fil wall_test_dis 5 -500 -500 C:\GIS\Layers\AgreeDEM NEGATIVE_NO
Start Time: Tue Jan 28 13:00:33 2020
Executing: PolylineToRaster C:\GIS\Layers\wall_test_dis.shp FID C:\Users\user007\AppData\Local\Temp\arc2C59\AH20200128100033\AgreeStrGeo MAXIMUM_LENGTH NONE C:\GIS\Layers\Fil
Succeeded at Tue Jan 28 13:00:33 2020 (Elapsed Time: 0.38 seconds)
Executing: Con C:\Users\user007\AppData\Local\Temp\arc2C59\AH20200128100033\AgreeStrGeo C:\GIS\Layers\fil C:\Users\user007\AppData\Local\Temp\arc2C59\AH20200128100033\AgreeStrDEM # #
Start Time: Tue Jan 28 13:00:34 2020
Succeeded at Tue Jan 28 13:00:34 2020 (Elapsed Time: 0.44 seconds)
Executing: Delete C:\Users\user007\AppData\Local\Temp\arc2C59\AH20200128100033\AgreeStrGeo RasterDataset
Succeeded at Tue Jan 28 13:00:34 2020 (Elapsed Time: 0.05 seconds)
Computing smooth drop/raise grid ..
Executing: Minus C:\Users\user007\AppData\Local\Temp\arc2C59\AH20200128100033\AgreeStrDEM -500 C:\Users\user007\AppData\Local\Temp\arc2C59\AH20200128100033\smoothGeo
Start Time: Tue Jan 28 13:00:35 2020
Succeeded at Tue Jan 28 13:00:35 2020 (Elapsed Time: 0.70 seconds)
Computing vector distance and allocation grids...
Executing: Int C:\Users\user007\AppData\Local\Temp\arc2C59\AH20200128100033\smoothGeo C:\Users\user007\AppData\Local\Temp\arc2C59\AH20200128100033\smoothGeoInt
Succeeded at Tue Jan 28 13:00:36 2020 (Elapsed Time: 0.36 seconds)
Executing: Delete C:\Users\user007\AppData\Local\Temp\arc2C59\AH20200128100033\AgreeStrDEM RasterDataset
Start Time: Tue Jan 28 13:00:36 2020
Succeeded at Tue Jan 28 13:00:36 2020 (Elapsed Time: 0.04 seconds)
Executing: EucAllocation C:\Users\user007\AppData\Local\Temp\arc2C59\AH20200128100033\smoothGeoInt C:\Users\user007\AppData\Local\Temp\arc2C59\AH20200128100033\vecEucAlloGeo 45 # 10 Value C:\Users\user007\AppData\Local\Temp\arc2C59\AH20200128100033\vecEucDistGeo # PLANAR
ERROR 999999: Error executing function.
Failed to execute (EucAllocation).
Failed at Tue Jan 28 13:00:37 2020 (Elapsed Time: 0.58 seconds)
System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component.
at ESRI.ArcGIS.Geoprocessing.GeoProcessorClass.Execute(String Name, IVariantArray ipValues, ITrackCancel pTrackCancel)
at ESRI.APWR.ApHydro.ArcHydroOp.DEMReconditioningGP(ApLayers apLayers, Double numCellsBuff, Double sharpDrop, Double smoothDrop, Boolean raiseNegative, Boolean bUsingStreamGridInput, ITrackCancel& trackcancel, IGPMessages& messages, String& exMessage)
Failed to execute (DEMReconditioning).
Failed at Tue Jan 28 13:00:37 2020 (Elapsed Time: 3.65 seconds)
Build Walls
DEM Reconditioning
Any clue about what went wrong?
Thanks!
TungNg
I deleted all temporary files in %temp% folder then tried with a much smaller area. This is the error
Messages
Executing: BuildWalls Fil 500 0 0 C:\GIS\Layers\Walled # wall_test_buf #
Start Time: Tue Jan 28 13:44:56 2020
System.Runtime.InteropServices.COMException (0x80004005): ERROR 010217: Unable to reclass on the selection set.
ERROR 010024: Error during conversion.
at ESRI.ArcGIS.SpatialAnalyst.RasterConditionalOpClass.Con(IGeoDataset ConditionalRaster, IGeoDataset TrueRaster, Object& FalseRaster)
at ESRI.APWR.ApHydro.ArcHydroOp.BuildWalls(ApLayers apLayers, Double innerWallHeight, Double wallBuffer, Double breachLineBuffer, ITrackCancel& trackcancel, IGPMessages& messages, String& exMessage) in C:\Builds\17\s\ArcHydroTools\src\ApHydro\ArcHydroOp.vb:line 13808
Failed at Tue Jan 28 13:44:58 2020 (Elapsed Time: 2.58 seconds)
LorenaLombana
Did you find the solution? I have the same problem 😞
