I initially published my data as a feature service layer so that symbology configurations would stay intact when publishing data.
After publishing my feature service layer, I grouped my data layers (tedious) for easier viewing. Then pushed it as a web map which contained said groupings.
Then housed under the new Experience App (preserves symbology > Web App Builder).
Upon subsequent data feature service layer overwrites I realized groups are not preserved (I do not want to build groups upon each subsequent data update and overwrite).
With that, I grouped my data layers in ArcPro (tedious). Then realized after the publishing analysis function that 'groups' are not preserved from Pro to ARCGOL (as a feature service layer), but web maps do preserve groups.
Decided to skip the feature service layer and publish as a web map. Web map requires I include a base map. Base map included, but now stating the service layer has a different projection than the maps projection. Do the auto fix and now my web map/basemap match and are in WGS 84. However my data layers are in NAD 83 State Plane California V FIPS 0405 (US Feet).
So with discovering what works and what I can and cannot do I will publish my web map with said grouped data layers. The web map is in WGS 84 and data layers all in the LA County specific projection California V FIPS 0405. Is this difference going to be a problem, or do I need to put these layers in WGS 84?
All this runaround because I wanted to create groups and preserve symbology.
