Hello,
I'm looking for a way to format the Title field of a pop-up in ArcGIS Online, both in terms of content and text formatting.
At the moment the Title area displays data from the field {name}. I would also like to pull in information from two additional fields, depending on whether the attribute field contains data for that particular record. I also want to put brackets around the values, but only want the brackets to display if the field contains data.
For example, the fields might be 'Name', 'Title', 'Alternate Title' and I would like it to display as:
Joe Blogs (Dr)
But if there is no title, then it would only display the name, e.g. Joe Blogs.
Hope that makes sense.
Thanks!
