Has anyone used the RTK locator from Metrotec and VIVAX
597
6
01-26-2023 11:20 AM
RobertBorchert
Frequent Contributor III
Our company has an underground location from Metrotec/Vivax and it uses a web application called VMMAP.
In the VMMAP page there is an option to Sync to ArcGIS Online.
I have created a connection to a service I created for the RTX data
I have matched the fields from VMMAX to my FeatureService.
However, there no instructions in their knowledgebase for this and I cannot determine how to push or sync the data with my ArcGIS Online account.
Anyone here have experience.
The only email contacts for the company are for sales.  I have written to two separate locations.
There knowledge base has no help documents that pertain.
RWATT
New Contributor III
Hi Robert,
Did you ever figure this out? I'd be curious to hear anything you learned about integrating these two systems.
RWATT
New Contributor III
I did eventually solve this with the help of the VM team. It's a little bit convoluted, but the basic tricks are that you need them to "upgrade" your account if it isn't setup as multi-user yet and your layer needs to contain sub-layers per point type.
BenjiSchwartz
Hello, have you synced this with Field maps at all?  I was hoping to collect data from the metrotec and have it directly log it in field maps.
RWATT
New Contributor III
Hi Benji,
I did have success with this and we are using it regularly. Could you share a little more about what issues you're facing, or what you've tried already?
TylerJones
New Contributor III
@RWATT , we just got a VLoc RTK. Is there a published feature class, your org or VM’s, that has the same schema/fields as the basic suggestions coming from VM for field mapping? The only thing I saw was a .pdf of the mapping process.
thanks,
RWATT
New Contributor III
I unfortunately don't have anything to share. The field names can be anything and are mapped in the VM process, so it might not be that useful anyways.
Best,
