How to activate "enable suggestions" search function in Portal Scene?
2429
05-03-2016 06:57 PM
Chieh-YungYu1
hi all
I am working with portal scene now, and trying to use my own geocoder for search function.
My Portal version is 10.3.1, Computer OS is Windows 7 SP1
Here is the situation, I found out that my search suggestion function is working in portal map, but doesn't work in portal scene. I know I need to add layers at first to enable search function in portal map, so maybe I should do the same thing in portal scene? But I can't find where I can setup this in portal scene, does anyone know where to setup it? Or enable suggestions function is just don't work in portal scene?
Thank you
Vincent Yu
