importing map to ArcGis
478
08-05-2010 02:24 PM
KrisChrysler
Does anyone know how to import your map you made online to ARC MAP  so you can add pins and layers?
MikeMinami
Esri Notable Contributor
ArcGIS Desktop version 10 supports opening maps you made in ArcGIS.com into ArcMap. Previous version of ArcGIS Desktop don't support this feature. However, you can essentially recreate the same map in ArcMap by adding the same map services you added to your web map.
Mike
