Impossible to add uploaded content to my map
755
05-18-2012 01:27 AM
JacopoGuerrini
Hello everyone,
I'm trying to create an online map with some content I correctly uploaded from ArcMap 10 ("Create Layer Package") to My Content.
But if I choose Add -> Find Layer -> Find "Campionamenti_C21" In: "My content" I get a "0 results found" message.
Note: the layer is online and it has public access permissions (http://www.arcgis.com/home/search.html?q=Campionamenti_C21&t=content)
Thanks in advance
JG
MikeMinami
Esri Notable Contributor
Layer packages can't be directly added to a web map. The things you can add to a web map are:
  • ArcGIS Server services
  • WMS services
  • ArcGIS Online hosted services (currently in beta testing)
Files that can be imported into a map are:
  • Shapefiles
  • CSVs files
  • GPX files
  • KML files
So, the way you would get your data to display on a web map are:
  • Publish your data to ArcGIS Server.
  • Publish your data to ArcGIS Online via an organizational subscription (fee based service due to release in 3rd quarter)
  • Create shapefiles of your data and import them onto a map. Due to browser limitations, you can only load about 1000 features onto the map.
hope this helps,
Mike
JeffAzevedo
I would suggest changing the access so you could try "My Organization" and see if that doesn't give you a different result.
MikeMinami
  • WMS services
  • Shapefiles
  • CSVs files
  • GPX files
  • KML files
hope this helps,
Mike
JacopoGuerrini
Ok, thanks Mike. I've imported the river network of my region, but I've a projection problem, such as an offset of about 50 m; the projected reference system is Monte Mario Italy 1. In ArcMap I don't have such problems.
I'll open a new post!
Edit: I've solved my projection problem converting the Shapefiles to UTM WGS84 32N. Now the offset is 0 m.
