I'm trying to configure the hosted Information lookup app with my data. Im searching for an address against my parcel layer, and I have configured the app to show the popup in the side panel.
For some reason, the search window is not getting fully populated with the address that I select from the suggestion list. I believe this is also causing the issue with the information panel returning more than one record. A 30 minute configuration is taking me days as I try to figure the issue with my configuration.
Has anyone else run into this issue?
Here's the map if you want to see the issue... , Information Lookup
Thanks in advance!
Please see my attached image.
