Is it possible to use an If Then Else statement in ArcGIS Online Label Expression
7492
05-30-2017 10:22 AM
EugeneDurshpek
New Contributor III
I'm attempting to add the following expression to a layer in AGOL, but not able to make it work...
Here's what I have in ArcGIS Desktop which works...
Function FindLabel ( [InspectionOrigin], [ClockFromTrans], [ClockFrom] )
if ( [InspectionOrigin] <> "D") then
FindLabel = ( [ClockFromTrans] )
elseif ( [InspectionOrigin] <> "U") then
FindLabel = [ClockFrom]
end if
End Function
I'm attempting to recreate this in AGOL for one of my layers and am unable to get it to work.
I've tried multiple options, none seem to be successful.
Option 1
IIf($feature.InspectionOrigin = Text($feature.InspectionOrigin, 'U'), $feature["ClockFromTrans"], $feature["ClockFrom"])
Option 2
IIf($feature.InspectionOrigin = 'U'), $feature["ClockFromTrans"], $feature["ClockFrom"])
Option 3
IIf($feature.InspectionOrigin <> 'D'), $feature["ClockFromTrans"], $feature["ClockFrom"])
Any thoughts?
Thanks!
Eugene D.
KenBuja
MVP Esteemed Contributor
There are a couple way of doing this. First would be to use an If statement
if ( $feature.InspectionOrigin != "D") {
  $feature.ClockFromTrans
else if ( $feature.InspectionOrigin != "U") {
  $feature.ClockFrom
You can also use the logical function IIF
iif ($feature.InspectionOrigin != "D", $feature.ClockFromTrans, $feature.ClockFrom)‍‍
The documentation has more examples: ArcGIS Arcade | ArcGIS for Developers
KenBuja
  $feature.ClockFrom
EugeneDurshpek
New Contributor III
Thank you Ken. This was exactly what I was looking for. The first option (using the "if statement") worked well. I wasn't able to get the "iif statement" to label features successfully.
Again; thank you very much!
Eugene D.
