Issue with publishing a Feature Service
12665
72
07-03-2013 06:14 AM
MatthesRieke
Hi all,
I have been trying to publish a hosted Feature Service based on a local data frame using ArcMap 10.1's "Share As/Service" feature (following the tutorial at http://resources.arcgis.com/en/help/arcgisonline/index.html#//010q00000087000000 ). Though, the service appears in "My Contents" (as a Service Definition, is that correct?) it is not published or accesible in any way (I have been trying to access it from GeoEvent Processor Beta). When I try to publish it manually (through the Item view's "Publish" button), I get an error message "Invalid tenant Id Invalid tenant login".
Publishing the same local data frame to my own ArcGIS Server 10.1 instance works. The TileService for the same data frame works as well. I am currently using the 30-day trial subscription, could this be an issue?
Thanks in advance,
Matthes
StephanieWendel
Hi petr_home, gaelangu, and inovaaalmeida!
Thanks for reporting this! Can you all try publishing again? Our team believes they were able to resolve the issue yesterday. If it's still a problem, please reply back to this post.
Thanks!
Stephanie
SumaMulpuru
Facing this issue while adding analysis to layer.
Subscription ID: 6445353796
StephanieWendel
Hi sumamulpuru‌!
We saw an occurrence of this yesterday morning but the team was able to address it. Are you still having issues publishing and/or running the analysis tool?
Thanks!
