Issues with AGOL replica removal using REST API and Python
449
03-24-2018 05:57 PM
AnthonyCheesman1
Occasional Contributor II
Hi everyone. Not quite where the home for this post should be, but I'll start in the AGOL group as you have all proven to be a very smart bunch of people in the past.
I'm currently banging my head against a brick wall trying to work out a programmatic way to list and then subsequently unregister replicas on an AGOL feature service.
This is what I've got in place at the moment:
1 - using https://www.arcgis.com/sharing/rest/oauth2/token/  to generate a token, with Client ID and Client Secret sourced from developers.arcgis.com
2 - using Python 'requests' library to pass a POST request to http://feature_service_url/replicas, with the token as payload and also f = pjson
This method above doesn't fail, but returns an empty JSON as the result.
If, however, I substitute in a token generated from the URL when I am logged into www.arcgis.com and view a feature service URL, a legitimate result will be returned.
What I can't work out is why will no result be returned when I am using a token generated by Step 1 above. I have used this in numerous other applications to interact with feature services without issue.
Can anyone shed any light on this?
Thanks
Anthony Cheesman
Tags (4)
