JavaScript in WebMap Popup-Configuration
1173
6
04-29-2020 04:29 AM
UlfGrimhardt1
Occasional Contributor II
is it possible to use JavaScript in the HTML Code in the PopUp-Configuration?
Instead of attributes i would like to use a json file to show informations of specific Features.
I hope someone can help!
Greetings from Germany
Ulf
Egge-Jan_Pollé
MVP Regular Contributor
Hi Ulf Grimhardt,
Did you have a look at the ArcGIS API for JavaScript?
In the Sample Code you will find a lot of nice examples of what you can do with popups, e.g.
HTH,
Egge-Jan
UlfGrimhardt1
Hi Egge-Jan,
thanks for the reply. I am afraid this is nothing i could use in the standard web app builder, right?
Ulf
Egge-Jan_Pollé
Hi Ulf Grimhardt,
For  map to be used in a web app, build with the Web AppBuilder for ArcGIS, you can configure the popup in the MapViewer.
Did you try something in the Custom Attribute Display? (see screen capture below)
BR,
Egge-Jan
UlfGrimhardt1
Yes i tried that, i'm afraid that i can use HTML but no JavaScript in the Display.
Egge-Jan_Pollé
Hi Ulf Grimhardt,
Did you have a look at Avenue, oh, no, sorry not Avenue, but Arcde? Did you have a look at the use of Arcade to configure your popup?
You might find some hints following this thread: https://community.esri.com/thread/207291-javascript-in-arcgis-online
BR,
Egge-Jan
mohansh1
Hi, I have the same question as @UlfGrimhardt1. I haven't found the solution yet also, it seems the Arcade doesn't seem to work now. Any further suggestion on how to config popup using the js?
