Launchpad Theme
1040
02-07-2018 03:26 AM
BrianHaren1
My organization has been using the Launchpad Theme template in Web App Builder for over a year. With the last ArcGIS Online update in December we noticed that on all of our current web apps, and all new ones built using the Launchpad template that the secondary text in the map title bar (the smaller text that is placed between the map title and the search window) is now pushed out of the title bar and appears below it. Note in the image below the text "by the H-JAIA Geospatial Engineering Group" that appears below the title/search bar. This text should be displaying inside the title bar:
We've tested several different possible fixes - shortening the text, removing spaces in the text, changing font sizes, etc. but nothing has an impact. We also know that this issue is not unique to our organization. I have the same issue in web apps created using my ArcGIS personal use site.
If anyone has found a fix for this I'd love to know about it, and hopefully it gets corrected across the AGOL platform on the next update.
Brian Haren
XanderBakker
Esri Esteemed Contributor
I am going to CC dlaw-esristaff‌ who may have some more information.
DerekLaw
Hi Brian,
We don't currently have a bug on this issue - where the secondary title text is placed outside of the Launchpad theme title bar. Can you please open an issue with Esri Tech Support and provide repro steps so they can investigate further?
Hope this helps,
KrystalPhaneuf3
I get similar errors when using this theme.  Sometimes the title displays fine, sometimes the search bar covers it or if there is no search bar sometimes the title gets pushed to below the header.  I am using Portal and Web App Builder.
