Layer cannot be added in scene: invalid or missing parameters
3764
11
03-23-2016 08:34 AM
EmmanuelVassilakis
I am trying to add an orthophoto map into a scene in arcgis online. The file (img) is hosted in a gis server outside esri and it was published into a service that also contains another two similar maps.
The file was added into ArcGIS Online using the following path: Add item (from My Content) > From the web > paste to url. In My Content is displayed as a feature layer.
When I try to add it in a scene i receive the message that the layer cannot be added because of invalid or missing parameters.
Any ideas?
P.S. If I add the whole service (all the 3 maps) then the map is opening correctly in the scene
GregoryL_Azou
You are welcome, I took another look and your swipe story looks good but the URL you used to embed it, is telling it to open the builder mode (which require authentication) as it include '&edit'
Replace http://nkua.maps.arcgis.com/apps/StorytellingSwipe/index.html?appid=9b962facbd8643b2a74330752a2dfa01... by http://nkua.maps.arcgis.com/apps/StorytellingSwipe/index.html?appid=9b962facbd8643b2a74330752a2dfa01​ and it should works
EmmanuelVassilakis
That what it! Thanks a lot again!
