Hi, if the output only shows the hot spots, it reveals that only statistically significant hot spots were identified in the analysis. The map contains no cold spots because none of them were detected in the analysis. If you click and open the legend of the output map, it should show a full legend including the hot spots, cold spots, and non-significant values. You can further confirm if cold spots exist in the output by checking the Gi Bin column in the output attribute table.
A feature with a low value may not be a statistically significant cold spot. Please refer to How Optimized Hot Spot Analysis works and How Hot Spot Analysis (Getis-Ord Gi*) works for more information and details on the mathematics and algorithms. If you want to identify spatial outliers instead of cold spots, Find Outliers will be the recommended tool to use.
