Overwrite Or Append a web feature layer Arcpy, ArcGIS Pro
3783
12
04-05-2020 07:36 AM
HushamMohamed
I have a dynamic query layer (polygon) derived from feature class and SQL table, I was able to share it to ArcGIS Online as a web layer.
1-  I would like to setup an automated workflow for overwriting or append to hosted feature services within our ArcGIS Online Account (stand alone arcpy script) and schedule that for everyday update. I tried this one Update Hosted Feature Service with Feature Class but got this error. I am not interested using Python API,
2- Where is the path of Query Layer (workspacePath) ?  I know its generated and already shared to ArcGIS Online.
3- also I went through this one Best Practise for scripting updating of hosted feature services?
  but none of  them helped.
HushamMohamed
I checked its Data source Path, nothing on the DB.
JakeSkinner
Esri Esteemed Contributor
Hi Husham,
The easiest approach would be to create a model and run the Delete Rows to delete all the records from the feature service, and then execute the Append tool to append features from a feature class to the feature service.
Once you have the model created, you can set this up to run at a prescribed time.  See the following help document on how to do this using ArcGIS Pro 2.5:
Schedule geoprocessing tools—ArcGIS Pro | Documentation
HushamMohamed
Thank you, Will try this easiest approach. and get back to you.
HushamMohamed
I created the Model for deleting and Appending,
and It work Perfect,  the problem now with the Schedule,I keep getting this error. I am not Sure Is windows related or ArcGIS Pro issue.
JakeSkinner
As an alternative, you can export the model to a python script, and then try configuring Windows Task Scheduler to execute the script:
https://community.esri.com/docs/DOC-14675-schedule-a-python-script-using-windows-task-scheduler
HushamMohamed
this exactly what I did, any how will figure it out, my main issue now is how to set the time field
because the append now reset the date/time field to UTC -5,  while I need it to be UTC -6 Central Time.
JasonSimpson
New Contributor III
Have you tried the convert time geoprocessing tool? I had this issue a few weeks back and had to incorporate this tool into my process. Not sure if this helps you, but it worked for me.
HushamMohamed
Did not worked for me, did your original date/time with your local time Like my Case?
Thanks
HushamMohamed
Hi Jake,
I've created  a model its working fine when I run it from the Model Builder - ArcGIS Pro, but which fails when it is scheduled.  In the Windows Scheduler window I get a (0x1) "Last Run Result" status.  Apparently when working with hosted layers it isn't as simple as it sounds.
Could you provide a simple example of how to create a model that interacts with a hosted feature class with windows Scheduler.
When you get time, I posted few questions here, still looking for answers.
Thanks
