Can someone please answer this? I have a Web Feature Layer on AGOL that contains points representing water meters. I also have a Table in Arc Pro that contains the current customer information for this month. The Web Layer and the Table have a common field called AccountNumber. I upload the Table to the same folder as the Web Layer. I open the map that contains the Web Layer and added the Table to the map. I then navigated to the Join Tool in Analytics, selected the Web Layer as the Target, and Table as the Join table. It completes successfully and creates a new Web Layer. Clicking on the point gives me all the fields from the original Web Layer, along with the fields from the Table.
Next month I will have a new table. To make life simple, I would like to Overwrite the Table contained on AGOL by using Share, Overwrite Table in Arc Pro. However, it appears that changing an attribute in the Table on AGOL has no affect on the Joined Web Layer so Overwriting will do me no good. I have tried several different ways to update this web layer without going through many steps, but I hit a road block every time.
The Table actually originates from a connection to a OLE DB. I export that database table to a Table and then push that to AGOL. I can also pull the OLE DB table over into the Table of Contents and I can create a local feature layer that updates automatically. It works great, but doesn't do me any good not being online. And it won't let me push that feature layer to AGOL because of something to do with the database being an old version. I wondered if I could create a "pipeline" to the table as some kind of workaround, but I haven't had a chance to look into it yet.
Much appreciated.
Travis
