Polygon symbology does not update after editing features in a web application.
652
09-20-2017 07:20 AM
ShelbyZemken2
I have parcel data that has a field associated with a status : ie zone 1, zone 2, zone 3.
The symbology is driven by these zone types.
When changing zone types using the edit widget, the symbology does not update, even though the attribute table shows the correct zone, the color does not. The color remains as the original zone symbology instead of the updated zone color.
Am I missing something?
JonathanQuinn
Esri Notable Contributor
This persists after panning or zooming within that area of interest?
ShelbyZemken2
Yes it does. I have tried to reset the symbology too. Its as if the symbology wont update anymore.
JonathanQuinn
I assume the data is not shared publicly, as it's an editable feature service?  Are you using domains within your data?
ShelbyZemken2
You are correct on both accounts. The data is sensitive and therefore private. The data was built within a file geodatabase in ArcDesktop 10.5, and uploaded to arc gis online, brought into a web map, then a web app, where it can be edited via dropdown. So do you think that the referential integrity that was setup by using domains is the reason there are symbology errors?
