Glad that worked 😄
Ok. I'm having the same IE spining problem.
Would you please take a look at this if you have a min.
http://maps.mckinneytexas.org/MapsGallery1.4/index.html
Thanks in advance for your help.
Tarig
In PMGT, is it possible to show attributes from multiple feature classes (parcels, school district, city limits) in the same pop-up window, when the user clicks on the map? Map is created using .MSD file utilizing data from SDE and published through ArcGIS server & PMGT.
If yes, Is it controlled by the Identify tool options in .MSD file?
Thanks in Advance.
VJ.
Greetings from Esri UK, PMG team and forum folk,
I was wondering if it would be possible to access additional groups from the right side pane?
It would make a great addition to the gallery, since one would be able to access related groups to the opening (main) one. Would you consider such an implementation for future versions?
Many thanks and cheers for now.
I have the 1.3 template customized and set up but would like to add the new legend features. Is there any easy way to add them to 1.3?
