Public Notification Widget problem with setup
5469
12
02-09-2018 08:41 AM
PeteCoventry3
I'm trying to setup the Public Notification Widget so that I can select, buffer and generate mailing labels on my webmap, but having trouble with the setup.  I've added the widget and started editing.  Under the "Search and Buffer Settings", I've added my hosted feature layer as the "Search Source".  This hosted feature layer is a parcel layer with ownership and mailing addresses.  When I proceed to the "Address Layers" tab there is no layer to select.
I've tried to follow the documentation about this widget, but still unclear where I'm going wrong?
I've attached screenshots to help illustrate.
Any feedback would be greatly appreciated!
Pete
StevenE
Robert,
Thank you for the quick reply. Yes I have. I tried all suggested solutions regarding using a map service layer, but to no avail. I am now trying to configure the widget with a geocoder, which is not mentioned in the link above.
Steven
RobertScheitlin__GISP
Steven,
  I think you still have to have a Address Layer though. I am not sure what advice to give beyond what was in that link. You will probably be better off contacting tech support.
ChetShuler
Has to be a feature service.
