Publishing to AGOL overwrites editor tracking data
9148
17
01-04-2017 11:30 AM
LeonS
Occasional Contributor III
I have a feature class that I maintain in a geodatabase that has editor tracking enabled.  It has the standard fields: created_user, created_date, last_edited_user and last_edited_date.  I'm using the python functions in arcpy.mp to create the SD draft and to stage the definition file. Then using the ArcGIS API for Python to update and publish the SD file in AGOL.
When I publish my map, all values in my editor tracking fields get overwritten with the date/time the script runs and the username that I use to login to AGOL.  If I choose to make those fields not visible in my Pro project, then no data appears in my updated service.  This happens despite having editing capabilities disabled.
Is there a way to prevent this overwrite from happening?  I would like the tracking information to reflect what I have in my geodatabase.
Best,
Leon
by Anonymous User
Not applicable
I was just thrown an ancient script (I'm pretty sure it was intended for 10.1?) and alerted it wasn't preserving editor tracking. This is not how I would write python or approach this, but any idea how to implement the same functionality y'all spoke about into it?
Kelly Gerrow
Leon Scott
# Update.py - update hosted feature services by replacing the .SD file
#   and calling publishing (with overwrite) to update the feature service
import ConfigParser
import ast
import os
import sys
import time
import urllib2
import urllib
import json
import mimetypes
import gzip
from io import BytesIO
import string
import random
from xml.etree import ElementTree as ET
import arcpy
class AGOLHandler(object):
    def __init__(self, username, password, serviceName, folderName, proxyDict):
        self.headers = {
            'Content-Type': 'application/x-www-form-urlencoded; charset=UTF-8',
            'User-Agent': ('updatehostedfeatureservice')
        self.username = username
        self.password = password
        self.base_url = "https://www.arcgis.com/sharing/rest"
        self.proxyDict = proxyDict
        self.serviceName = serviceName
        self.token = self.getToken(username, password)
        self.itemID = self.findItem("Feature Service")
        self.SDitemID = self.findItem("Service Definition")
        self.folderName = folderName
        self.folderID = self.findFolder()
    def getToken(self, username, password, exp=60):
        referer = "http://www.arcgis.com/"
        query_dict = {'username': username,
                      'password': password,
                      'expiration': str(exp),
                      'client': 'referer',
                      'referer': referer,
                      'f': 'json'}
        token_url = '{}/generateToken'.format(self.base_url)
        token_response = self.url_request(token_url, query_dict, 'POST')
        if "token" not in token_response:
            print(token_response['error'])
            sys.exit()
        else:
            return token_response['token']
    def findItem(self, findType):
        """ Find the itemID of whats being updated
        searchURL = self.base_url + "/search"
        query_dict = {'f': 'json',
                      'token': self.token,
                      'q': "title:\"" + self.serviceName + "\"AND owner:\"" +
                      self.username + "\" AND type:\"" + findType + "\""}
        jsonResponse = self.url_request(searchURL, query_dict, 'POST')
        if jsonResponse['total'] == 0:
            print("\nCould not find a service to update. Check the service name in the settings.ini")
            sys.exit()
        else:
            resultList = jsonResponse['results']
            for it in resultList:
                if it["title"] == self.serviceName:
                    print("found {} : {}").format(findType, it["id"])
                    return it["id"]
    def findFolder(self, folderName=None):
        """ Find the ID of the folder containing the service
        if self.folderName == "None":
            return ""
        findURL = "{}/content/users/{}".format(self.base_url, self.username)
                      'num': 1,
                      'token': self.token}
        jsonResponse = self.url_request(findURL, query_dict, 'POST')
        for folder in jsonResponse['folders']:
            if folder['title'] == self.folderName:
                return folder['id']
        print("\nCould not find the specified folder name provided in the settings.ini")
        print("-- If your content is in the root folder, change the folder name to 'None'")
        sys.exit()
    def upload(self, fileName, tags, description):
         Overwrite the SD on AGOL with the new SD.
         This method uses 3rd party module: requests
        updateURL = '{}/content/users/{}/{}/items/{}/update'.format(self.base_url, self.username,
        self.folderID, self.SDitemID)
        query_dict = {"filename": fileName,
                      "type": "Service Definition",
                      "title": self.serviceName,
                      "tags": tags,
                      "description": description,
                      "f": "json",
                      'multipart': 'true',
                      "token": self.token}
        details = {'filename': fileName}
        add_item_res = self.url_request(updateURL, query_dict, "POST", "", details)
        itemPartJSON = self._add_part(fileName, add_item_res['id'], "Service Definition")
        if "success" in itemPartJSON:
            itemPartID = itemPartJSON['id']
            commit_response = self.commit(itemPartID)
            # valid states: partial | processing | failed | completed
            status = 'processing'
            while status == 'processing' or status == 'partial':
                status = self.item_status(itemPartID)['status']
                time.sleep(1.5)
            print("updated SD:   {}".format(itemPartID))
            return True
        else:
            print("\n.sd file not uploaded. Check the errors and try again.\n")
            print(itemPartJSON)
            sys.exit()
    def _add_part(self, file_to_upload, item_id, upload_type=None):
        """ Add the item to the portal in chunks.
        def read_in_chunks(file_object, chunk_size=10000000):
            """Generate file chunks of 10MB"""
            while True:
                data = file_object.read(chunk_size)
                if not data:
                    break
                yield data
        url = '{}/content/users/{}/items/{}/addPart'.format(self.base_url, self.username, item_id)
        with open(file_to_upload, 'rb') as f:
            for part_num, piece in enumerate(read_in_chunks(f), start=1):
                title = os.path.basename(file_to_upload)
                files = {"file": {"filename": file_to_upload, "content": piece}}
                params = {
                    'f': "json",
                    'partNum': part_num,
                    'title': title,
                    'itemType': 'file',
                    'type': upload_type
                request_data, request_headers = self.multipart_request(params, files)
                resp = self.url_request(url, request_data, "MULTIPART", request_headers)
        return resp
    def item_status(self, item_id):
        """ Gets the status of an item.
        Returns:
            The item's status. (partial | processing | failed | completed)
        url = '{}/content/users/{}/items/{}/status'.format(self.base_url, self.username, item_id)
        parameters = {'token': self.token,
                      'f': 'json'}
        return self.url_request(url, parameters)
    def commit(self, item_id):
        """ Commits an item that was uploaded as multipart
        url = '{}/content/users/{}/items/{}/commit'.format(self.base_url, self.username, item_id)
                      'f': 'json'}
    def publish(self):
        """ Publish the existing SD on AGOL (it will be turned into a Feature Service)
        publishURL = '{}/content/users/{}/publish'.format(self.base_url, self.username)
        query_dict = {'itemID': self.SDitemID,
                      'filetype': 'serviceDefinition',
                      'overwrite': 'true',
                      'f': 'json',
        jsonResponse = self.url_request(publishURL, query_dict, 'POST')
        try:
            if not jsonResponse['services'][0]['success']:
                print("Cannot proceed with publishing, error: \n   {}".format(
                    jsonResponse['services'][0]['error']))
                sys.exit()
            else:
                print("successfully updated...{}...".format(jsonResponse['services']))
        except Exception as e:
            print("Problem reading response: \n {}".format(e))
        return jsonResponse['services'][0]['serviceItemId']
    def enableSharing(self, newItemID, everyone, orgs, groups):
        """ Share an item with everyone, the organization and/or groups
        shareURL = '{}/content/users/{}/{}/items/{}/share'.format(self.base_url, self.username,
        self.folderID, newItemID)
        if groups is None:
            groups = ''
                      'everyone': everyone,
                      'org': orgs,
                      'groups': groups,
        jsonResponse = self.url_request(shareURL, query_dict, 'POST')
        print("successfully shared...{}...".format(jsonResponse['itemId']))
    def url_request(self, in_url, request_parameters, request_type='GET',
                    additional_headers=None, files=None, repeat=0):
        Make a request to the portal, provided a portal URL
        and request parameters, returns portal response.
        Arguments:
            in_url -- portal url
            request_parameters -- dictionary of request parameters.
            request_type -- HTTP verb (default: GET)
            additional_headers -- any headers to pass along with the request.
            files -- any files to send.
            repeat -- repeat the request up to this number of times.
        Returns:
            dictionary of response from portal instance.
        if request_type == 'GET':
            req = urllib2.Request('?'.join((in_url, urllib.urlencode(request_parameters))))
        elif request_type == 'MULTIPART':
            req = urllib2.Request(in_url, request_parameters)
        else:
                in_url, urllib.urlencode(request_parameters), self.headers)
        if additional_headers:
            for key, value in list(additional_headers.items()):
                req.add_header(key, value)
        req.add_header('Accept-encoding', 'gzip')
        if self.proxyDict:
            p = urllib2.ProxyHandler(self.proxyDict)
            auth = urllib2.HTTPBasicAuthHandler()
            opener = urllib2.build_opener(p, auth, urllib2.HTTPHandler)
            urllib2.install_opener(opener)
        response = urllib2.urlopen(req)
        if response.info().get('Content-Encoding') == 'gzip':
            buf = BytesIO(response.read())
            with gzip.GzipFile(fileobj=buf) as gzip_file:
                response_bytes = gzip_file.read()
        else:
            response_bytes = response.read()
        response_text = response_bytes.decode('UTF-8')
        response_json = json.loads(response_text)
        if not response_json or "error" in response_json:
            rerun = False
            if repeat > 0:
                repeat -= 1
                rerun = True
            if rerun:
                time.sleep(2)
                response_json = self.url_request(
                    in_url, request_parameters, request_type,
                    additional_headers, files, repeat)
        return response_json
    def multipart_request(self, params, files):
        """ Uploads files as multipart/form-data. files is a dict and must
            contain the required keys "filename" and "content". The "mimetype"
            value is optional and if not specified will use mimetypes.guess_type
            to determine the type or use type application/octet-stream. params
            is a dict containing the parameters to be passed in the HTTP
            POST request.
            content = open(file_path, "rb").read()
            files = {"file": {"filename": "some_file.sd", "content": content}}
            params = {"f": "json", "token": token, "type": item_type,
                      "title": title, "tags": tags, "description": description}
            data, headers = multipart_request(params, files)
        # Get mix of letters and digits to form boundary.
        letters_digits = "".join(string.digits + string.ascii_letters)
        boundary = "----WebKitFormBoundary{}".format("".join(random.choice(letters_digits) for i in range(16)))
        file_lines = []
        # Parse the params and files dicts to build the multipart request.
        for name, value in params.iteritems():
            file_lines.extend(("--{}".format(boundary),
                               'Content-Disposition: form-data; name="{}"'.format(name),
                               "", str(value)))
        for name, value in files.items():
            if "filename" in value:
                filename = value.get("filename")
            else:
                raise Exception("The filename key is required.")
            if "mimetype" in value:
                mimetype = value.get("mimetype")
            else:
                mimetype = mimetypes.guess_type(filename)[0] or "application/octet-stream"
            if "content" in value:
                                   'Content-Disposition: form-data; name="{}"; filename="{}"'.format(name, filename),
                                   "Content-Type: {}".format(mimetype), "",
                                   (value.get("content"))))
            else:
                raise Exception("The content key is required.")
        # Create the end of the form boundary.
        file_lines.extend(("--{}--".format(boundary), ""))
        request_data = "\r\n".join(file_lines)
        request_headers = {"Content-Type": "multipart/form-data; boundary={}".format(boundary),
                           "Content-Length": str(len(request_data))}
        return request_data, request_headers
def makeSD(MXD, serviceName, tempDir, outputSD, maxRecords, tags, summary):
    """ create a draft SD and modify the properties to overwrite an existing FS
    arcpy.env.overwriteOutput = True
    # All paths are built by joining names to the tempPath
    SDdraft = os.path.join(tempDir, "tempdraft.sddraft")
    newSDdraft = os.path.join(tempDir, "updatedDraft.sddraft")
    # Check the MXD for summary and tags, if empty, push them in.
    try:
        mappingMXD = arcpy.mapping.MapDocument(MXD)
        if mappingMXD.tags == "":
            mappingMXD.tags = tags
            mappingMXD.save()
        if mappingMXD.summary == "":
            mappingMXD.summary = summary
            mappingMXD.save()
    except IOError:
        print("IOError on save, do you have the MXD open? Summary/tag info not pushed to MXD, publishing may fail.")
    arcpy.mapping.CreateMapSDDraft(MXD, SDdraft, serviceName, "MY_HOSTED_SERVICES")
    # Read the contents of the original SDDraft into an xml parser
    doc = ET.parse(SDdraft)
    root_elem = doc.getroot()
    if root_elem.tag != "SVCManifest":
        raise ValueError("Root tag is incorrect. Is {} a .sddraft file?".format(SDDraft))
    # The following 6 code pieces modify the SDDraft from a new MapService
    # with caching capabilities to a FeatureService with Query,Create,
    # Update,Delete,Uploads,Editing capabilities as well as the ability
    # to set the max records on the service.
    # The first two lines (commented out) are no longer necessary as the FS
    # is now being deleted and re-published, not truly overwritten as is the
    # case when publishing from Desktop.
    # The last three pieces change Map to Feature Service, disable caching
    # and set appropriate capabilities. You can customize the capabilities by
    # removing items.
    # Note you cannot disable Query from a Feature Service.
    # doc.find("./Type").text = "esriServiceDefinitionType_Replacement"
    # doc.find("./State").text = "esriSDState_Published"
    # Change service type from map service to feature service
    for config in doc.findall("./Configurations/SVCConfiguration/TypeName"):
        if config.text == "MapServer":
            config.text = "FeatureServer"
    # Turn off caching
    for prop in doc.findall("./Configurations/SVCConfiguration/Definition/" +
                            "ConfigurationProperties/PropertyArray/" +
                            "PropertySetProperty"):
        if prop.find("Key").text == 'isCached':
            prop.find("Value").text = "false"
        if prop.find("Key").text == 'maxRecordCount':
            prop.find("Value").text = maxRecords
    # Turn on feature access capabilities
    for prop in doc.findall("./Configurations/SVCConfiguration/Definition/Info/PropertyArray/PropertySetProperty"):
        if prop.find("Key").text == 'WebCapabilities':
            prop.find("Value").text = "Query"
    # Add the namespaces which get stripped, back into the .SD
    root_elem.attrib["xmlns:typens"] = 'http://www.esri.com/schemas/ArcGIS/10.1'
    root_elem.attrib["xmlns:xs"] = 'http://www.w3.org/2001/XMLSchema'
    # Write the new draft to disk
    with open(newSDdraft, 'w') as f:
        doc.write(f, 'utf-8')
    # Analyze the service
    analysis = arcpy.mapping.AnalyzeForSD(newSDdraft)
    if analysis['errors'] == {}:
        # Stage the service
        arcpy.StageService_server(newSDdraft, outputSD)
        print("Created {}".format(outputSD))
    else:
        # If the sddraft analysis contained errors, display them and quit.
        print("Errors in analyze: \n {}".format(analysis['errors']))
        sys.exit()
if __name__ == "__main__":
    # start
    print("Starting Feature Service publish process")
    # Find and gather settings from the ini file
    localPath = sys.path[0]
    settingsFile = os.path.join(localPath, "settings.ini")
    if os.path.isfile(settingsFile):
        config = ConfigParser.ConfigParser()
        config.read(settingsFile)
    else:
        print("INI file not found. \nMake sure a valid 'settings.ini' file exists in the same directory as this script.")
        sys.exit()
    # AGOL Credentials
    inputUsername = config.get('AGOL', 'USER')
    inputPswd = config.get('AGOL', 'PASS')
    # FS values
    MXD = config.get('FS_INFO', 'MXD')
    serviceName = config.get('FS_INFO', 'SERVICENAME')
    folderName = config.get('FS_INFO', 'FOLDERNAME')
    tags = config.get('FS_INFO', 'TAGS')
    summary = config.get('FS_INFO', 'DESCRIPTION')
    maxRecords = config.get('FS_INFO', 'MAXRECORDS')
    # Share FS to: everyone, org, groups
    shared = config.get('FS_SHARE', 'SHARE')
    everyone = config.get('FS_SHARE', 'EVERYONE')
    orgs = config.get('FS_SHARE', 'ORG')
    groups = config.get('FS_SHARE', 'GROUPS')  # Groups are by ID. Multiple groups comma separated
    use_prxy = config.get('PROXY', 'USEPROXY')
    pxy_srvr = config.get('PROXY', 'SERVER')
    pxy_port = config.get('PROXY', 'PORT')
    pxy_user = config.get('PROXY', 'USER')
    pxy_pass = config.get('PROXY', 'PASS')
    proxyDict = {}
    if ast.literal_eval(use_prxy):
        http_proxy = "http://" + pxy_user + ":" + pxy_pass + "@" + pxy_srvr + ":" + pxy_port
        https_proxy = "http://" + pxy_user + ":" + pxy_pass + "@" + pxy_srvr + ":" + pxy_port
        ftp_proxy = "http://" + pxy_user + ":" + pxy_pass + "@" + pxy_srvr + ":" + pxy_port
        proxyDict = {"http": http_proxy, "https": https_proxy, "ftp": ftp_proxy}
    # create a temp directory under the script
    tempDir = os.path.join(localPath, "tempDir")
    if not os.path.isdir(tempDir):
        os.mkdir(tempDir)
    finalSD = os.path.join(tempDir, serviceName + ".sd")
    # initialize AGOLHandler class
    agol = AGOLHandler(inputUsername, inputPswd, serviceName, folderName, proxyDict)
    # Turn map document into .SD file for uploading
    makeSD(MXD, serviceName, tempDir, finalSD, maxRecords, tags, summary)
    # overwrite the existing .SD on arcgis.com
    if agol.upload(finalSD, tags, summary):
        # publish the sd which was just uploaded
        fsID = agol.publish()
        # share the item
        if ast.literal_eval(shared):
            agol.enableSharing(fsID, everyone, orgs, groups)
        print("\nfinished.")
I have no idea why this relatively simple task was written in 500 lines of python.
LeonS
This is definitely predates the ArcGIS API for Python!  It's much simpler now.
I have a script on GitHub that might help you out.  It requires using an ArcGIS Pro project.
GitHub - LeonGIS/UpdateHostedFeatureSvc_Pro: ArcGIS Online administrative python scripts
Hope it helps!
Leon
KellyGerrow
Esri Frequent Contributor
Andrew Valenski‌, I would also recommend re-writing this using the Python API as you can condense this significantly.
That being said, lines 205- 228 contain the publishing logic by making direct calls to Publish through the REST API.
To modify this script to maintain edits, add a publishParameters to querydict. They are optional parameters when publishing from SD files which weren't available when this script was put together:
http://resources.arcgis.com/en/help/arcgis-rest-api/index.html#/Publish_Item/02r300000080000000/
                      'publishParameters': '{"editorTrackingInfo":{"enableEditorTracking":true,"preserveEditUsersAndTimeStamps":true}}',
                      'f': 'json',
-Kelly
by Anonymous User
Not applicable
Oh I absolutely agree this needs to be burned to the ground. First gotta get the trash working before we can replace it though
I'll give this a whirl and let you know what I find!
ScottMoore__Olympia_
I was able to republish my SD file by going to the hosted notebook server at https://notebooks.esri.com and running this updated ArcGIS API for Python code:
from arcgis.gis import GIS
sd_itemid = "a71a0a30cd0e4cde9d196f99e935a919"
gis = GIS("https://www.arcgis.com", "YourAGOLUserName")
#Find SD file, then update or add, then publish
sd_item = gis.content.get(sd_itemid)
#Parameters for editor tracking
pub_params = {"editorTrackingInfo" : {"enableEditorTracking":'true', "preserveEditUsersAndTimestamps":'true'}}
sd_item.publish(publish_parameters=pub_params, overwrite=True)
As of 3/19/19, we can now update the ownership information after a hosted feature service is published.  I know this isn't the exact issue in this post, but it may be part of a solution for others.
https://community.esri.com/people/smoore-esristaff/blog/2019/03/21/updating-editor-tracking-data-in-...
NataliyaLys
Scott Moore (Olympia)‌ your solution to update the SD file with the provided code worked great! Thank you.
Awesome!  I am glad it helped you out.
