Hello All,
I would like to get some help on the following issue that I encountered in ArcGis 10.3
The objective is to look through the whole string and remove just the "." from the string
Object ID Field
1 Apple.
2 Orange.
3 Egg
4 Pear
5 Watermelon
I've tried using the following code which resulted in the all the last characters being removed instead of just "." :
Trim( LEFT ([Field], LEN( [Field]) -1))
I've also tried the code below which prompted an error message "Type mismatch" for both iif and InStr :
Trim(Left([Field], iif((InStr([Field], ".") = LEN([Field])), InStr([Field], ".")-1, LEN([Field]))))
I am using the Field Calculator in ArcGis 10.3.
Thanks for any help in advance.
