Small Integer Fields and Dashboard List Widget Advanced Formatting
176
03-12-2024 08:45 AM
mpboyle
Is there a bug or limitation to the data types that can be used within Advanced Formatting of a list widget within Dashboards?
If I enable Advanced Formatting on a list widget in a dashboard and attempt to create a variable using a small integer field, none of my fields that are of a small integer data type are returned, they all throw an error as not being found.
These fields DO show in the data table view, as well as the available fields in the Line Item template.
In the screenshot below, you can see all small integer data type fields generate an error in Advanced Formatting.  They ARE available and display in the Line Item template, and ARE visible in the Data Table view.
David_Tipping
Hi - did you get anywhere with this issue? Looks like I'm in the same boat here: https://community.esri.com/t5/arcgis-dashboards-questions/dashboard-list-expression-fields-not-avail...
David 😀
mpboyle
Esri support confirmed the behavior and has logged it as a bug.
David_Tipping
So I got a solution from another contributor detailed in my post here: Solved: Re: Dashboard list expression - Fields not availab... - Esri Community
Love this community 👍
David Tipping
