Update Vector Tile Script Error
567
11-05-2018 01:23 PM
deleted-user-8TJ6jZDO1Rfr
I'm trying  to run the OverWriteVectorTilePackage script to update vector tiles but I'm receiving an error. Any idea how I can fix the 'itemID'?
Script Location: https://slco.maps.arcgis.com/home/item.html?id=e94507f5477b4a2c9ecbd1b198e0fad2
Kelly Gerrow
Tags (3)
Printing the the unpack dictionary helped. I found a syntax error in my layerName ... typical.
Thanks so much!
KellyGerrow
Esri Frequent Contributor
Hi James,
Did you update the script with your vector tile package item id? The variable is inItemID (line 74).
-Kelly
Kelly, thanks for the quick reply!
Yes I did update the variables for my data. Not sure what else I could be missing.
Here is what I get.
KellyGerrow
Can you print and paste the unpack dictionary?
Thanks so much!
