Uploaded table to ArcGIS Online no data
318
01-29-2019 09:01 AM
MatthewCory
I have tables that were in MS Access. I made it a File Geodatabase and added them to a map in ArcMap. Everything is fine, I can see all the data in all the tables. When I share as a service everything uploads (no errors when analyzed) the other tables that were treated the same way all have data but one (tbl_Inspections) does not. Reading online I found a solution to make sure no fields were hidden, no hidden fields. I have tried this several times and more ways than I can remember with the same results.
Any suggestions?
