Web Map App - Search Widget - Popup problems
602
05-13-2018 06:51 PM
MelissaBrooks
Hi there,
I've noticed in Web Appbuilder when configuring the search widget to search a field within a layer that the popup does two undesirable things.
- The Attachments links do not show up
- The fields are not in the right order, they are not even in the default order
Image attached for illustration
I've tested in both Chrome 66.0.3359.170 and IE11
Is this a known issue? I assumed the popups would be the same
Short of turning off the "Show pop-up when the feature or location is found." option in the search widget, I'm not sure what could be changed.
Ideas welcomed
Melissa Brooks
Senior Geospatial Systems Specialist
Tasman District Council (New Zealand)
TonyGroeneveld2
Noticed in my case if I created a new Search layer the web map popup appeared. Did a comparison of the json for the widget and noticed that for the layer that was not showing the web map popup that layerID was set to null. After a replaced the null with the web map layer id, the web map popup showed.
Not sure how the layerID got set to null.
