Web map viewer is not loading in some edge browsers
2652
7
02-14-2018 11:38 AM
SurendranNeelakantan
New Contributor III
The site
www.arcgis.com/home/webmap/viewer.html   is not loading  in some edge browsers.  I am getting a blank page. I tried clear cache.
The Error message  I am getting is
Current window: www.arcgis.com/home/webmap/viewer.html
SCRIPT12004: An internal error occurred in the Microsoft Internet extensions
dojo.js (20,67)
any help ?
by Anonymous User
Not applicable
I was not able to reproduce this. Are you on the most current version of Edge? You can see the version by opening the edge settings and scrolling down to the bottom of the window.
New Contributor III
This is the version
Microsoft Edge 40.15063.674.0
Microsoft EdgeHTML 15.15063
Please find attached screenshot
I tested on  another computer with edge, where  it  works fine.
Both versions looks same.
by Anonymous User
Not applicable
Since the issue appears to be machine specific perhaps try clearing the browser cache.
New Contributor III
Katie,
I don't think it is  browser cache issue. The issue exists more than one Machine. I have no clue  of what could be the issue.
by Anonymous User
Not applicable
If you can consistently reproduce it I would recommend opening a support case.
JeffCook1
New Contributor III
I have the same problem. Sometime the tiny urls do not work in Edge, On other machines, the Edge will not load any of my web apps. It will not connect to the server that I am using for my map information.
Here are few of the web apps that are not working in Edge on my work computer
https://trails.idaho.gov/
ArcGIS Web Application
ValerieHanson
New Contributor III
Hi Jeff,  Its been a couple years since you posted this error ... do you recall how it was resolved?  I'm having the same issue after our I.T. Dept ran some upgrades to Edge.  My REST services show up in the browser (https://servername/arcgis/REST) but not in the web apps, nor can i bring one into a new Map in portal.
Thanks much, Valerie
