Good morning Carmel,
Thank you for your interest in the solution to my issue!
Yes, it is the new builder (so I should acknowledge that I am using the out-of-the-box app template option).
Yes, I am adding the points individually.
Yes, I receive some errors in F12, but I don't understand what any of it means. But since my workflow,
which has been sufficient until now, hasn't changed, and the problem presented itself after several years without issue
on the preexisting application, I am dubious that the issue is error introduced on my end outside of the change of the OS
from 7 to 10. My colleague, who is still running 7 does not experience this issue.
I'm happy to make any setting adjustments that are necessary, I just need to know what they are.
Matt
