When ready to create a traverse that has a ground to grid correction required, the process is to hover over the icon, and then select one of the two options: 1) Enter the ground direction and distance and then draw it, or 2) draw the ground line and grid line.
I would like to add a third option: 3) Select line with appropriate grid correction already applied.
Not sure if wording is good, but what I mean is that if I have a line with good cogo and positioning already, I should be able to have the program determine the correct ground to grid correction that would make the cogo line I selected work.
