So currently I am using ArcGIS Pro in dark theme mode and so the grayish connector lines in model builder don't look distinctive enough compared to the dark back ground. Hence it'd be nice to be able to modify of the color and maybe even the thickness of the connector lines. This option(s) can be put under the diagram tab and/or under project>options>model builder.
I too have suggested a similar improvement.
@DuncanHornby Nice maybe the two ideas could be merged together to add more emphasis 🙂
