Allow Decimals and Negative Margins in Label Properties
450
02-10-2017 02:16 AM
Status: Implemented
MarkWigley
In order to create a Balloon Callout which closer matches the Text being used it would be great if the Margins (Left, Right, Top and Bottom) could be finely adjusted by supporting both decimal points and negative values as is the case by the X and Y Offset parameters.
2 Comments
JustinConnerWR
Shadow X/Y offsets are also limited to integers.  This is not helpful unless you're using huge text.  This is awful:
WendyHarrison
Hi Mark
negative values and decimals are supported
Wendy
