When setting the display properties of a field in a table, you are only allowed to align a numbers to the right or the left. When I use the 'add table to layout' function, the numbers are shwon in the table at the extreme edge of the column (either right or left depending on how I have set the alignment). Why is there not an option to align 'center'? Is there a way I can atleast disply the number with a couple of spaces from the edge of the table when I 'add table to layout'"?
