The right-click menu in ArcGIS Pro is missing numerous functions that are available in ArcMap. These functions need to be as comprehensive, or more so in Pro. Example one of many: In need of a map within a few minutes during a board meeting, I was joining a table to a feature class. I needed to check that the field used for the join had the same properties so that the join is successful and trouble-free. In the attribute table, right-click on a field>Properties shows you within a second, literally. Right-click in ArcGIS Pro doesn't have "properties". Nor was I able to find it after scanning the contextual ribbons or "project window" for more than a few minutes. It was quicker to open up ArcMap and reload the data. The more I use Pro, the more disappointed I am. I am quickly finding out any time "saved" in a 64 bit environment is quickly negated due to the qwerky workflows and dysfunctional interface of Pro. I couldn't care less about a "slick and buttery" interface. "Slick and buttery" doesn't get work done.
After forcing Pro onto myself for over a month, I am officially downgrading it to heavy processing where the multi-threading can be utilized. It is in no condition for replacement of ArcMap.
