ArcMap COGO Traverse Tool - Simplify Line and Curve entry
870
04-27-2010 06:02 PM
Status: Closed
ChrisBridges
New Contributor II
COGO Traverse Tool in ArcMap does not need a drop-down to select between line and curve entry, etc.
It should all be there all available already in the one form, similar to how it was in ArcGIS 8.x.  If lines and curves were both already available, then as folks enter bearing and distance, or chords, radius, length, etc. they would not have to have their hands leave the keyboard, going back and forth between mouse and keyboard, switching between lines and curves.
3 Comments
TiffanyPuett1
(+) will tab you forward and (/) will tab you backward. I use the num lock key to activate the arrow keys which allows me to switch from curves to lines and back again using only one hand.
AmirBar-Maor
The new traverse tool in ArcGIS Pro 1.3 does not require you to specify if you are entering a straight line or a curve. It also has many useful handy shortcuts to gain maximum efficiency and is designed for a single hand entry (numbers keyboard) .
This link can help you get started.
Amir
AmirBar-Maor
Status changed to: Closed
ArcMap's lifecycle is in a mature status and is scheduled to be deprecated in 2026
