arcpy.mp open mapx map files and pagx layout files
1518
05-20-2016 05:48 AM
Status: Closed
AlexanderGray
Occasional Contributor III
Arcpy.mp allows you to open project and layer files.  The GUI allow you to save maps and layouts and layer files.  We need to be able to open map and layer files in arcpy.mp to modify the update connection properties and other properties before loading the in the project.  Having all the possible maps and layouts a users would want to use in a project is not practical if it numbers in the dozens and only a few are used at the time.  This way you can build a library of mapx and pagx files to use in your projects.
2 Comments
JeffBarrette
Does ArcGISProject.ImportDocument() satisfy your needs?  It allows you to import mapx, pagx and more into a project?  We also support exporting to these formats.
Or do you want to be able to connect to a pagx or mapx and repair datasources directly on those?  A work around would be to importDocument into a project, change datasources and then export back to the appropriate X file.
Jeff - arcpy.mp and Layout teams.
JeffBarrette
Status changed to: Closed
Given you can use importDocument(path to mapx), change data sources, then export back to mapx, this lessens the priority of creating additional classes and members given a fair amount of other planned development work.
If the above workflow does NOT work for you, please describe in detail you scenario and we could reconsider.
Jeff - Layout and arcpy.mp teams
