Create and Restore Road Networks through XML in Geodatabase Designer
341
04-27-2010 12:38 AM
Status: Closed
KristofferWaage_Beck
New Contributor III
In Geodatabase Designer you are able to extract geometric network, topology, relationships, etc to XML.
The XML export can be used to restore the a geometric network, topology etc. with the same setup as the original.
This is a really usefull functionality, but why is Road Networks omited from this functionality?
Please include the same XML export/import of Road Networks in Geodatabase Designer.
Best regards
Kristoffer
Informi GIS A/S
1 Comment
SSWoodward
Status changed to: Closed
This idea has been closed as a duplicate of the Data Management Idea linked below. Don't worry, you can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
https://community.esri.com/t5/data-management-ideas/create-and-restore-road-networks-through-xml-in/...
