Credit Estimator Publishing Web Layers. When publishing from ArcGIS Pro to ArcGIS Online, users should be notified how large that dataset is and roughly how many credit it will be consuming. We are working through an issue with support where a feature class we are publishing out of an SDE database is consuming 10x Feature Data Storage than publishing the same feature class from a file geodatabase or shapefile. Currently we have several features layers that are consuming 10x the feature data storage than they should.
